Yamaha RX-V2600 help
Does anyone have RS-232 protocol info, working code block, or working module for this receiver? I've been looking, and I've found a couple of references to the protocol doc via google, but the link doesn't go anywhere on Yamaha's site anymore. Also, I have a code block and module from the 2500 that I know work, but I can't get the 2600 to respond to anything using them. Thanks in advance for anything you guys have that may help.
--John
I normally use the regular AMX module for the RX-V2500 and it works fine for most of the commands. Anything that doesn't, I use the PASSTHRU= command in the AMX module and insert whatever custom commands I need.
I'm attaching the protocol for the 1600/2600. Let me know if you need help with it - we used to use a lot of these receivers, though now we have moved on to the 1700/2700 which also have slight differences from the usual protocol.
Eric
