Nxc-vol4 Problem
I don know if somebody could help me with volume control card
I?ve connected netlinx module to NI-2000 and in netlinx online tree automatically appears
"32001 - NXC-Vol4 download"
well I suppose that in my source code i have to write
dvVolume1=32001:1:0
dvVolume2=32001:2:0
I save, compile and send to Master
Then when I refresh online tree appears
"32002 - NXC-Vol4 download", it ?ve changed
why?
  • vincenvincen Junior Member
    It's normal behaviour of netlinx control cards when they are brand new ;) They are setup with dynamic adress so adress of card can change at each boot of system.
    First thing you have to do is setup a fixed adress in range of 1-31999, you can do that in NetLinx Studio through Device Adressing menu ;)
    Then you'll be able to adress your card in program with a fixed adress and it should work better :D
    Vinc
  • JustinCJustinC Junior Member
    Go to Diagnostics and Device Addressing at the bottom:
    Enter the Device and System numbers that you want to assign to the device in the (Change to Device) Device and System text boxes.
    Note: The Destination System number must be a System that is defined in the URL List dialog.
    Click the Start Identify Mode button to place the named System in ID Mode. The text box below this button displays a Waiting?Press Cancel to Quit message. The Start Identify Mode button changes to Cancel Identify Mode (click to cancel ID Mode).
    Press the ID button on the back of the NetModuleShell.
  • etrujilloetrujillo Junior Member
    Thank?s
    Thank?s for your help.
