Looking for a DVD-R with Audio Meters
I need to incorporate a DVD-R into a setup where we will be recording events in the room, but we can't monitor the DVD-R as it records. I'd really like to find one with audio meters either on the front of the DVD-R itself or on the display, just so I can watch to make sure the audio is passing to it correctly. Has anyone run into anything that does this?
  • We had an instance where 'confirmation of recording' was required (part of a spec) recently.
    We found the Phillips DVDR985 was easy enough for the end user to administer..
    ...was not under AMX control, so did not assess this side of it.
