Best way for tuner channel display
Hey all,
I'm kind of new at this and I would like to know the best way to display current DSS tuner channel info on the TP and in addition giving feedback when the number buttons or channel up/down is pushed so the (faux) feedback is real time. Also, if a tuner channel is selected but not confirmed (by pushing enter) the channel display should revert back to the current channel. I am trying to work out a scheme with a variable, but I am having trouble. It is IR so no buffer for the tuner. This is kind of a novice issue, but I would appreciate any tips.
Thanks in advance.
Thanks in advance.
1. Permit ONLY the AMX processor to control the sat receiver. This means hide it in a rack and lock it down.
2. You will need to create an array of ALL available channels.
3. You will have to ONLY send discrete channel changes, no CH+ or CH- IR codes. You can still have CH+/- buttons, but each push will have to send a complete channel (ie 005. 006. 007.... )
4. You have to remember to adjust the current channel based on favorite buttons and direct channel input and update the current channel accordingly so that CH+ and CH- work.
5. You have to remove ANY interaction with the guide on the receiver (unless you want to do A LOT of coding).
Optionally, you could provide a way to add and remove channels from the array (to deal with channel changes)
Keep in mind that this will slow down the operation considerably when using CH+ and CH-. You will also still have the potential to have the wrong feedback if the receiver is in guide mode when the channel info is sent, gets an error that requires user intervention, have to wait for signal to be located.... Obviously, by sending discrete channels, you should be able to get the correct channel reporting after the cause of the problem has been remedied and the user pushes CH+/-/FAV button.
Those are the hurdles that I can think of. The way I do it, is I track the easy ones like direct channel entry and favorite button pushes. The minute I see an arrow button push or a CH+/-, I change the channel feedback to unknown.
P.S.
I would like to hear other approaches to this problem in hopes that I have over complicated the issue.
You forgot one:
6. Pray that your IR emitter never falls off!
Creating feedback code for a device that has no true feedback
is always a challenge.
I dont know of an easy solution. As your steps indicate, you simply
have to take the time to anticipate every scenario that the client
may encounter, and code as necessary.
The only bad thing is that there is no hardware to blame when it
decides to have a fluke day!
As far as channels for something like a DSS receiver, I am using a preset list stored on my master, and explicitly telling my customers that the feedback only reflects the last channel explicitly selected by the system, and cannot know if someone chose a channel then hit channel up or down a few times. The fact that channels can be skipped based on subscription, location, etc., makes it impossible to track ups and down without continuous updates to the system, so I won't even offer it anymore if the device itself doesn't report back where it is.
LMAO, I haven't had any fall off in at least 2 mins.(That I know about.)
I agree that I only do feedback for DSS on customer favorite selection, everything is momentary. I give full control of the dss guide with the touch panel. This is much more easier and never is wrong.
I haven't had an emitter fall off in the last minute either, but had one fall off yesterday.
In situations where we're using a receiver to only provide an audio source we've fed the video into the house video mux and feed an output from there to a video server that then allows us to put a little window with the active video on the touchpanel page.
To simple stick the flasher on with only the supplied sticky back is IMHO is inadeqauate and a poor installation practice. I'd rather throw away a $10.00 flasher if a piece of equipment needs replacement than make a service call to a pissed off customer because a flasher fell off when ever the cleaning crews comes through.
To get back on subject feedback on TV channels isn't all that important to me. Momentary is fine. If the customer forgets where they are let them push the "info" button.
Well that had me puzzled so I Googled it and for those of us who are similarly puzzled:
Super Glue (Cyanoacrylate adhesive)
Ah, thanks, it never occurred to me I was using a local variant.
