OFFing an Array of Buttons
TurnipTruck
I would like to do something like this as a means of mutual exclusivity for the sake of feedback:
However this does not work. Does anyone have a suggested alternative for a one-line button-feedback-array killer? I don't want to define as mutually exclusive.
Thanks!
INTEGER cnFEEDBACKS[10]={1,2,3,4,5,6,7,8,9,10}
OFF [dvTP,cnFEEDBCAKS]
Thanks!
Is your 'dvTP' an array? It should work if it's a DEV but won't work for an array.
I can't see an easy way to do it with out a loop.
The following function seems to work::define_function funBtnArrayKill(dev dvDevice,integer nArrayIn[]) { stack_var integer i for(i = 1; i < length_array(nArrayIn) +1; i++) { off[dvDevice,nArrayIn[i]] } } -
This is basically the same code I posted yesterday on a different thread but this version uses a function in the button event to give the appearance of one line of code but of course it requires the added block of code with in the function. This handles ON as well as OFF in the same manner as Mutually Exclusive probably does.
DEFINE_DEVICE dvTPSwitcher = 10001:1:0 ; dvSwitcher = 5001:1:0 ; DEFINE_FUNCTION fnHandleSwitcherBtnFBack(INTEGER iStartingINdex,INTEGER iBtn) { stack_var integer i ; for (i = iStartingINdex ; i <= iStartingINdex + 7 ; i ++)//handle feedback { if (iBtn == i) { ON [dvTPSwitcher,nSwitcherBtnArry[i]] ; } else { OFF [dvTPSwitcher,nSwitcherBtnArry[i]] ; } } } DEFINE_VARIABLE volatile integer nSwitcherBtnArry[] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17} ; BUTTON_EVENT [dvTPSwitcher,nSwitcherBtnArry] { PUSH: { stack_var integer nSwitcherIN ; stack_var integer nSwitcherOUT ; stack_var integer nBtn ; nBtn = get_last(nSwitcherBtnArry) ; Select { ACTIVE (nBtn >= 1 && nBtn <= 8)://select switcher input { nSwitcherIN = nBtn ; fnHandleSwitcherBtnFBack(1,nBtn) } ACTIVE (nBtn >= 9 && nBtn <= 16)://select switcher output { nSwitcherOUT = nBtn ; fnHandleSwitcherBtnFBack(9,nBtn) } ACTIVE (nBtn == 17)://take in & out { TO [dvTPSwitcher,nSwitcherBtnArry[17]] ; send_string dvSwitcher,"ITOA(nSwitcherIN),'*',ITOA(nSwitcherOUT),'!',13,10" ; } } } } -
I haven't had a chance to test it, but shouldn't a DevChan array do the trick?
DEVCHAN dcFeedback[] = {{device,1}, {device,2}, {device,3}, {device,4}} OFF[dcFeedback]
--D -
dchristo wrote:I haven't had a chance to test it, but shouldn't a DevChan array do the trick?
--D
That will work, but I don't like DEVCHANs. I just array the button channel numbers and reference the array. Makes for less code.
