1st experience w/Mio Keypads
This is the first time I've worked with the Mio's
I'm adding some buttons to an exisiting installation how do you pull button channel programing from the devices. Also how do you send it.
I tried file tranfer and keep getting errors.
Thanks for any assistance
brian
  • In Keypad Builder, you've got to specify the IP of the controller (not the keypad itself) to send the files to. If that doesn't work, maybe more info would help: controller? connection mode (serial/IP)?
  • Kouya
    Kouya Junior Member
    The controller is NI2000, and the keypads are connected via Axlink. I can see the keypad in the online tree when connecting IP. File tranfer timesout and fail when I try to pull the program files
  • Kouya wrote:
    The controller is NI2000, and the keypads are connected vis Axlink.
    Urk... I'm a bit of a Newbie myself; I was hoping I could contribute a simple answer to the forum, but I've never run those keypads off AxLink, so I don't have any other ideas for you. Sorry.
  • Colin
    Colin Junior Member
    Mio Keypads
    Which model of Mio are you running?
  • Kouya
    Kouya Junior Member
    They are Mio Classic-D panels
  • Check the Device ID:
    "I can see the keypad in the online tree when connecting IP. File tranfer timesout and fail when I try to pull the program files".
    Make sure you have the correct device ID specified in the "Send Configuration Files" dialog of the KeypadBuilder application. You must specify a full device ID (ie. a D:P:S like 130:1:4561). If you see the keypad device in the online of NetLinx Studio, then you should be able to send the file down to the device via the KeypadBuilder application.
