Anyone Tried AMX Module with Sony STR-DA3200ES?
Greetings,
Has anyone tries the module used for the DA4/DA7ES receiver with the newer DA-3200ES?
Just curious before I open a can of worms.
    I'll reply to myself.
    It works fine.
  • GregGreg Junior Member
    So far on the 5200 (pretty much the same as the 3200 I think) all my 232 works, but the receiver won't come on from an off-state. In the past I enabled CIS mode in the menu and that fixed the problem. However, I'm not seeing that on this line of receivers.
  • pauldpauld Junior Member
    We were having the same problems with the 5200, but we found the "installer Mode" in the menu and that fixed it. It is in the settings menu, multi zone, options. The setting was hard to find, it was 3 or 4 menus down in On Screen Display. I hope this helps.
    Paul
