G4 Web Control ? Max # of Connections
In the G4 Web Control settings under Protected Setup there is a field for Max Number of Connections and it is set to 1. How do I change it to a number > 1?
Thanks.
  • vincen
    vincen Junior Member
    As of now you can't change that value in any Modero Panels :( Perhaps an evolution for future ?? but i'm curious to know how AMX will able more than one connection as VNC is not supposed to manage more than one connection in same time !
    Vinc
  • Yes it can! VNC's can host multiple connections at the same time. In fact I just did it to verify with one connection from my TP to my desktop and a second from my laptop to my desktop.
    If I recall (I could just pull it up, but..) there is a setting in the property admin section of the VNC which allows you to choose the number of simultaneous connections to allow. I believe this is true of REAL and ULTRA which are the only ones I've played with.
    The TPs should also be capable if AMX chooses. At least one would think!
