Page tracking
Was wondering if there was a way of having a browser based panel being able to track to the current page of a real touchpanel. Currently, if we open a web based panel we automatically go to the starting page of the panel even if the real panel is on a different page. Once the web panel is open it tracks fine, but we are looking for a way to have the web panel open to the current page of the real panel no matter where it is.
I have looked at the TPAGEON command along with buffers but that only seems applicable to two real panels not a web based one.
My other thought was to try and send the current page to a variable and then send that information to the web based panel on a semi regular basis, but that seems like a lot more work then this should take.
Thoughts would be appreciated.
One way is to use your current page variable and send the correct page to the web based panel when the ONLINE event fires off for the web panel.
It would look something like this:
Hope this helps.
Cheers,
Joe
Just a question about the tracking. Would each page flip have to be done via the program or would the "previous" command on the panel work? I suspect it would not but want to have this verified.
Good question but I don't know since I don't use page tracking. I'm simply suggesting that the syncing page flip should occur (however it's tracked) when the ONLINE event fires vs. sending the page commands to the web based panel on a semi-regular basis. Other than that I'm of little use.
