Dell W5001C
undrtkr
Installing an AMX system for a client and they are providing 2 50" Dell W5001C plasma tv's. I searched on AMX's website for any Dell IR codes and they only list 2, W3000 & W4200. Also looking at the manual for the 5001 it states you can use Phillips Codes if you don't have a remote.
Has anyone programmed a room with the W5001C, if so will either of the 2 IR files on AMX's website work. Will ANY Phillips remote code work with the 5001 as well?
Ok, I've just been given a document from the client that lists the IR Hex commands for the plasmas. I haven't tinkered much with IREdit but can I create an IR file and plug these hex codes into it?
Definitely. Just create the model etc in IREdit, and highlight the button along the top called "Discrete IR hex codes". Follow the prompts and cut and paste.
