Transfer Aborted - Firmware ID is invalid
joelw
joelw Junior Member
I'm attempting to load most recent firmware into a ME260-64 running v2.31.137.
2010-64_ME260-64_Master_v3_12_335.kit
Right when the first file should be sent I get a dialog box stating:
"Transfer Aborted - Firmware ID is invalid"
Is there a way around this?
    You first have to update the master to 2.31.139 before a v3 update can be done. This is a "special" with the ME260 cards.
  • joelw
    joelw Junior Member
    Great, Thanks!
  • pdanford
    pdanford Junior Member
    No Luck
    I did this - update to 139 - and still get that same message "ID Invalid". Any other suggestion?
  • Marc Scheibein
    Marc Scheibein Junior Member
    Is your ME card really a NXC-ME260-64 ? A ME260 can not be updated to Duet.
    >show device 0
    Local devices for system #3 (This System)
    Device (ID)Model                 (ID)Mfg                    FWID  Version
    00000  (00256)NXC-ME260/64M      (00001)AMX Corp.           00336 v3.12.335
           (PID=0:OID=0) Serial=0,0,0,0,0,0,0,0,0,0,0,0,
           Physical Address=IP 172.16.100.10:1319 (00:60:9f:90:7a:54)
             (00256)vxWorks Image    (00001)                    00337 v3.12.335
             (PID=0:OID=1) Serial=N/A
             (00256)BootROM          (00001)                    00338 v3.00.316
             (PID=0:OID=2) Serial=N/A
             (00256)AXLink I/F uContr(00001)                    00270 v1.03.14
             (PID=0:OID=3) Serial=0000000000000000
  • Stephen Bolton
    Stephen Bolton Junior Member
    >show device 0
    Marc is absolutely right. The 64 cannot be upgraded to duet.
  • Marc Scheibein
    I think you mean "ONLY the 64 can be upgraded to Duet" :-)
  • Stephen Bolton
    Apologies for misrepresenting you Marc!
    It's the NXC-ME that cannot be upgraded to Duet (I incorrectly thought I was referencing this box).
  • Marc Scheibein
    No problem :)
