Meeting Manager Lamp hours
Anyone know how to setup Meeting Manager to report more than one lamp? Have projectors with 2 lamps, others with 4 lamps. My code is polling projector and parsing the lamp data. Just need to send the lamps to Meeting Manager. For rooms with single lamp projectors I have it working fine. Just need to tackle the multilamp projectors. With Code-Crafter can I just define additional lamps to monitor? Will they all show up in lamp hour reports?
  • Binu
    Binu Junior Member
    Lamp Hour
    May be the following will help u. Have a look
    DEFINE_VARIABLE
    char sProjResponse[100]
    integer nLampHour
    DEFINE_EVENT
    DATA_EVENT[dvProj]
    ONLINE:
    SEND_COMMAND dvProj, 'SET BAUD 19200,N,8,1'
    string:
    sProjResponse = data.text
    sProjResponse = set_length_array(sProjResponse,length_array(sProjResponse)-1)
    nLampHour = atoi(sProjResponse)
    RMSSetLampHours(dvProj, nLampHour)
    clear_buffer sProjResponse
    BUTTON_EVENT[dvTP,1]
    PUSH:
    on [dvTP,1]
    off [dvTP,2]
    SEND_STRING dvProj,"'CR3',$0D"
    RMSSetDevicePower(dvProj,TRUE)
    BUTTON_EVENT[dvTP,2]
    PUSH:
    on [dvTP,2]
    off [dvTP,1]
    RMSSetDevicePower(dvProj,FALSE)
  • MeetingManager Lamp Hours
    Kurt,
    You can add a second lamp to a single projector with CodeCrafter easily using the "Add Parameter" window. Simply add the parameter to the Projector Device and name it accordingly. CodeCrafter will create a function wrapper that allows you to place your polled lamp hours into the function and it will appear under your projector as a second lamp.
    I hope this helps!
    Doug Hall
    RMS Product Manager
  • Kurt
    Kurt Junior Member
    Projectors with multiple lamps
    Doug Hall wrote:
    Kurt,
    I hope this helps!
    Doug Hall
    RMS Product Manager
    Doug,
    Seems this would add a parameter which I could name Lamp2 or whatever. But will it show up in lamp hour reports?
  • Lamp Hours
    Good point, the next best method woulf be to add a second projector and as he same device and plug in the second lamp hours. I believe that would give you the necessary empirical data.
  • Kurt
    Kurt Junior Member
    Thanks Doug,
    I would assume I need to make the '2nd projector' a unique virtual device. I don't think I can have the same device show up twice. Anyway, this should give me the lamp hours into the reports. Also have heard that future upgrades to MM may support muliple lamps in a device directly.
