Finding a CR in a String
Greetings,
I have a string in which I need to replace $0D with $0A.
I am trying to locate the $0D with:
nWHERE=FIND_STRING(cVBL_TEXT_TO_SEND,$0D,3)
All I get is a 0 for nWHERE.
Any better suggestions for finding and replacing the CR?
Thanks.
  • Same old single character string thing
    Put quotes around any single character string to make it work properly:
    nWHERE=FIND_STRING(cVBL_TEXT_TO_SEND,"$0D",3)
  • In case you don't have the function, this is one that Dave got from the functions.axi file that kickin about.
    The function!
    DEFINE_FUNCTION CHAR[2000] fnReplace(CHAR strSTR[], CHAR strSEARCH[], CHAR strREPLACE[])
         STACK_VAR INTEGER nPOS
         STACK_VAR CHAR strTRASH[2000]
         STACK_VAR CHAR strTEMP_STR[2000]
         nPOS = FIND_STRING(strSTR, "strSEARCH", 1)
         IF (!nPOS)
    	  RETURN strSTR;
         WHILE (nPOS)
    	  strTEMP_STR = ""
    	  IF (nPOS > 1)
    	       strTEMP_STR = LEFT_STRING(strSTR, nPOS - 1)
    	  strTRASH = REMOVE_STRING(strSTR, "strTEMP_STR, strSEARCH", 1)
    	  strSTR = "strTEMP_STR, strREPLACE, strSTR"
    	  nPOS = FIND_STRING(strSTR, "strSEARCH", nPOS + LENGTH_STRING(strREPLACE))
         RETURN strSTR;
    Line to invoke the function.
     cYourThing = fnReplace(get_buffer_string(StringThing,nFBS - 1), "13", "10")
  • bquerrybquerry Junior Member
    functions.axi
    >>In case you don't have the function, this is one that Dave got from the functions.axi file that kickin about.<<
    Sounds like that could be a very useful file to have. Where could I get it? Or could someone email that file to me? I NEVER like to re-invent wheels...
    Bill Querry
    bquerry@crescentdigital.com
    Crescent Digital, LLC
    Tech Notes 659-662
    Check out the following Tech Notes for some useful string functions:
    TN659 - TRIM_STRING
    TN660 - FIND_STRING_REV
    TN661 - REPLACE_STRING
    TN662 - SPLIT_STRING
  • Well it wasn't really functions.axi this function was in strings.axi but in the zip there's dates.axi and math.axi.
    Just so the right people get credited, the original strings.axi and math.axi files come from Leon ten Brundel, and can be found in this thread: http://www.amxforums.com/showthread.php?t=77 . I don't believe I have touched the math.axi file, but I have made quite a lot of changes to strings.axi ... mainly adding functions to it as I have found useful (and, I must confess, changning the names of some of Leon's originals just out of sheer fussiness for naming conventions I have personally adopted). The dates.axi file is all mine (and so would be any blame for bugs in it I have missed :)).
    This particular function is all Leon :).
