NS2 Build 163 Autosave
Anyone noticed an issue with autosave?????
When Studio auto saves your code, it randomly jumps you to somewhere other than the line you were working on???
Bit of a pain in the ***!
We also found this, but with manually save. It randomly happens if the cursor is "in the first 4-5 screen pages" (we haven't found an exact line number range...) and you do a save, then the cursor jumps to about line 4....
It's reported to AMX.
More than a bit of a pain, it?s been driving me bonkers. It?s not just autosave, it?s any kind of save. And if you have a large file with folded code it not only jumps the screen around but it will also unfold code.
I don?t know what the above quoted BUG FIX is supposed to have fixed but it appears to have caused the problems we?ve been encountering. I decided to try and turn off the "Automatically Stamp File with Creation and Last Modified Date" option and found that the save problem disappears.
Hopefully this bug fix will get fixed in the next release. Until then, turn off the auto stamp option and life will be good.
