Axcent 3 Internal Trouble
in AMX Hardware
Greetings,
I have an Axcent 3 that does not seem to boot properly.
After applying power, you do not get the normal flash of all front panel LEDs. Instead, after a minute or so serial 1,4 and 2,3 TX flash back and forth.
I tried removing the batteries, but it did not help.
Any ideas?
Thank you.
Any ideas?
Thank you.
I have stumbled across Axcent 3s occasionally that have trouble loading IR files. Removing the batteries to clear the memory solves the problem. However, recently I have killed two Axcent 3s this way.
Any comment from AMX? Please!
Thank you!
