Learning Timelines
This is going to be a dumb question, but I'm going nuts trying to figure out how timelines work.
I tried to create a timeline for my underground sprinklers:
Technically, case 5 shouldn't need those off commands as they were already executed above, but I tossed them in during troubleshooting when the thing wouldn't turn off.
I am starting the timeline with:
Seems straightforward enough. I also added the ability to "cycle" to the next zone:
The timeline does not behave as expected:
1. When I turn it on, it takes several seconds before it activates, which is rather annoying. Same thing if I try to cycle - it just sits there for awhile before responding.
2. When I cycle to the next zone, it actually activates each zone in turn first! For example, say zone 2 is on, and I switch to zone 3. After several seconds, zone 2 will go off. Then zone 1 will come on for a few seconds, and go off. Zone 2 comes on, goes off. Zone 3 comes on and starts running. What's that all about??
I think I've followed the docs well enough here.. am I missing something? Did I do something wrong? I've been at this for several hours and am quite frustrated at this point.
Thank you for any advice.
timeline_event[tlSprinklers] {
// turn all zones off
off[dev_axf1_8relay1,1]
off[dev_axf1_8relay1,2]
off[dev_axf1_8relay1,3]
off[dev_axf1_8relay1,4]
off[dev_axf1_8relay1,5]
// keep track of sequence for use elsewhere in program
varTlSprinklersSeq = timeline.sequence
// advance to the correct zone
switch(timeline.sequence) {
case 1: { on[dev_axf1_8relay1,1] }
case 2: { on[dev_axf1_8relay1,2] }
case 3: { on[dev_axf1_8relay1,3] }
case 4: { on[dev_axf1_8relay1,4] on[dev_axf1_8relay1,5] }
case 5: {
} // switch
} // timeline_event
button_event [devAllMSP, 16] {
push: {
to [devAllMSP, 16]
if (timeline_active(tlSprinklers)) { timeline_set (tlSprinklers, 5) } // shut it down
else { // start it up
varTimeArray[1] = 9000
varTimeArray[2] = 3000
varTimeArray[3] = 6000
varTimeArray[4] = 15000
varTimeArray[5] = 1
timeline_create(tlSprinklers, varTimeArray, 5, timeline_relative, timeline_once)
} // else
} // push
} // button_event
button_event [devAllMSP, 15] {
push: {
to [devAllMSP, 15]
if (timeline_active(tlSprinklers)) { timeline_set (tlSprinklers, varTlSprinklersSeq + 1) }
} // push
} // button_event
It's not possible to modify the sequence number because it is tracked within the Timeline instance only.
If you want to jump to the next sequence, you have to set the timer to trigger the next sequence. In your case, to get to sequence 3 started right now, the command is Personally I always set my timer some milliseconds before the time of the array.
