G3 web interface
in AMX Hardware
Hi guys,
I'd like to ask you something about G3 web inteface:
a) how many simple (not too complicated) G3 web panels can an NI controller (ex.NI700) have?
b)can more than one users load his own panel at the same time? (not the same panel)
Thank you all,
George
Thank you all,
George
a) As many as the master has memory to store the web pages and graphics for. This will vary with the size of the Web Control pojects, but for an NI-700, it comes out to quite a few.
b) Yes. If it's not the same panel, there is no issue I am aware of. I'm sure there is some manner of limit as to how many connections the master will alllow, but I am pretty sure it's high enough you don't need to worry about it. If you need to have multiple instances of the same panel open, that can be done as well, there is a Tech Note dealing with the issue, and though I haven't done it in a long while, I don't recall it being very difficult.
If you are using the v3 firmware (aka DUET firmware), it's highly recommended to size up the memory range reserved for Duet. By default the Duet memory is only 1MegaByte of the Master's RAM, which is too less just to operate the webserver, and which is not enough to also support G3 Webcontrol. We use a minimum of 5 Meg, but I can remember a technote recommending 12 Meg.
To resize the memory, use the following terminal command:
