RS232 or IR codes for the Sharp LC-37D6U/LC-26D6U series
Has anyone got the rs232 codes for this or maybe an ir file?
thanks
edit : hmm never mind found it in the owners manual most have missed it when I looked before
  • DHawthorne
    DHawthorne Junior Member
    There are a few threads on this product line. One waring you may have missed: if using RS-232, turn the power savings features off. If power-savings is active, the RS-232 port turns off when the set is on standby, and you will have no way to turn it back on with that port.
  • ondrovic
    ondrovic Junior Member
    thanks will have to make sure I do that :)
  • Sharp TV control Sucks
    I've had to use both IR and 232 on certain Sharp LCDs. Because the discrete power and input codes dont work on certain models. But when the TV power goes off so does the 232 port. So I have needed to use IR for a toggle power, but 232 power off as an anchor and 232 for my input switching.
    The worst thing is, is that it is not model specific. I had 4 Sharps, same model, but different serial and 3 out of the 4 TVs worked with IR discrets.
  • DHawthorne
    There is a code you can send that will keep the port from shutting off with the power. It's detailed in this post: http://www.amxforums.com/showthread.php?t=576 .
