G4 Panel Builder error!!
J.Y.
J.Y. Junior Member
Dear all,
Do you ever meet the same problem like me(see attached file)
I sometimes use the G4 Panel Builder to help me.
But,.....when I finish my edit , and want to generate TP4 file
the error occur
It's so sad to me
  • DHawthorne
    DHawthorne Junior Member
    Yes, it happens to me all the time. If I save the project, reboot my computer, then reload the project and and try again, it works. I have not yet figured out what causes it in the first place, but it seems any project I start from scratch messes up. The same, by the way, goes for Visual Architect (probably uses the same code for panel generation). No amount of closing programs or freeing memory or drive space does a thing, but a reboot will. I strongly suspect some necessary files are getting flagged as being open that prevents the process from moving forward.
