MVP-8400, NI-3000 & keybeeps
How can I change the beeping sound heard when a button is pressed from the default to something else I provide?
I've tried uploading a WAV file into the panel (which can play when I trigger with a SOU command so I know the panel likes it) but I cannot get it to play on a keypress. I've tried setting the 'sound' event in Netlynx for the button & I've also tried setting this at runtime with ^BSO but no go. All I get is the default beep sound.
This, placed in the ONLINE event for the panel, does work so I know the found file is present and good:
SEND_COMMAND TP, "'@SOU-mybeep.wav'"
This command below, presumably, sets the sound for state 1 (off) of button 100 to the same beep as above. It does not work. This is sent immediately after the above in the ONLINE event so I know the panel is receiving it.
SEND_COMMAND TP, "'^BSO-100,1,mybeep.wav'"
This must be terribly easy as I've searched these forums high and low and find no references to such things.. what am I missing?
Ty
-J
Ty
-J
BUTTON_EVENT[dvTP,0] { PUSH: { SEND_COMMAND BUTTON.INPUT.DEVICE, "'@SOU-mybeep.wav'" } }When you say button 100 are you saying a button with the channel code of 100 or the address code of 100? It needs to be a button with the address code of 100.Makes sense, I'd just thought there was an inbuilt way for the panel to beep when it registers a button press.
The button has its address code set to 100. The channel code for this button is 10.
In any event, what does "^BSO" actually do? The way the docs read it sounds like it sets a sound that will be played when a touch 'hit' is registered on a particular button. If thats not what it is supposed to do, I wonder what it really is to do? Likewise for the "sound" parameter in both the ON and OFF states of a button in TPDesign....?
-J
Yup yup, this is what I thought and the behavior I am seeing.
So what do most of you guys do about keybeeps on panels -- do you disable this sound all together or just leave the defaulted AMX sound?
This was actually discussed in the P2 class I took in Tampa in April of '05. You can replace the default sound by going to the sounds folder of the AMX system pages on your computer. It's usually this: Here, you'll see audioTest, doubleBeep and singleBeep. If you copy the files out of there and put them in a different folder (for safe keeping), then rename the wav file you wish to use as your default "beep" to singleBeep or doubleBeep then upload with not doing a smart transfer, but a full system transfer, you'll be able to use your files instead of the default AMX. (.... whew - talk about a run-on sentence.)
I've done this with graphics as well, such as the so called "custom frame". (http://www.amxforums.com/showthread.php?t=598)
I am in no way responsible for any damages this may cause.
