Toshiba HD-Xa1 RS232 Codes
locknar
does anyone have the codes for the Toshiba HDDVD player?
Here is a thread at Remote Central that describes the RS-232 codes:
http://www.remotecentral.com/cgi-bin/mboard/rc-touch/thread.cgi?1160
I'll post the text in case the thread goes AWOL in the future.
HTHRemote Central.com wrote:
Here are RS232C Serial Commands for Toshiba's new HD DVD Player
serial communications protocol consists of start codes (4bytes), function code (2bytes), and reversal function code (2 bytes) for Toshiba HD DVD Player
Start code 0x45 and 0xB5
Example to send a pause code "00"
0x45,0xB5,0x00,0xFF
Example to send a Play code "15"
0x45,0xB5,0x15,0xEA
RS232C protocol:
3 wire 9600bps /8 data bits /1 stop bit /no parity /no flow control
9 pin male D connector DB9
pin 2 is receive
pin 3 is transmit
pin 5 is signal ground
start code: "45 + "B5"
Table of functions
00 Pause/step
01 1
02 2
03 3
04 4
05 5
06 6
07 7
08 8
09 9
0A 0
0D Slow
12 Power ON/Standby
13 Forward
14 Stop
15 Play
16 Display (Navi)
19 Review
1B Cancel
20 Setup
21 Enter
22 Return
23 Skip (back)
24 Skip (forward)
25 +10
26 T. Search
27 Audio
28 Subtitle
29 Angle
2B Repeat (VCR=Play Mode)
31 Door
32 Tab
33 Cursor
34 A
35 B
36 C
37 D
38 Return from Menu (resume)
41 Dimmer
4D Right
4E I/P Selector (resolution)
51 Left
80 UP
81 Down
82 Upper Right
83 Lower Right
84 Menu
85 Lower Left
86 Upper Right
92 Power ON
93 Power OFF
9F HDMI
DE Title (Top Menu)
EF Clear
F5 Open/Close
what is the reversal function code and how do you determine it
Subtract the function code from 255 and you have the reversal function code. -
thanks
thanks for the speedy response I gave this a quick try with no luck. I tried it as "$45$B5 etc
but I noticed it says the start command is four bytes, so "45 B5" in ascii translates to 8 bytes in hex, so the question is how do you read this -
I haven?t got any experience with this unit so I can only venture a guess.
My first would be to try:
Play
SEND_STRING dvDVD, ?45B515EA?
If that doesn?t work then I would try:
Play
SEND_STRING dvDVD, ?$45,$B5,$15,$EA?
But since the description says 8 bytes for the command I?m leaning towards the first SEND_STRING. Do either of the above work? -
Here is the correct string to send for PLAY and I can confirm it works:
SEND_STRING dvDVD,"$45,$B5,$15,$EA"
The protocol is somewhat misleading since it leads one to believe each command is 8 bytes long (which is obviously wrong and only 4 bytes)
Note: The discreet Power Off (code $93) does not work. Hopefully Toshiba will fix this in the future. So like the Hotel California, you can check out anytime you like but you can never leave.
