Cable max length using RS232
I read it somewhere but can't remember. What's AMX recommendation on MAX length on RS-232 control? I couldn't find it in Tech Notes.
Brian
Brian
Thanks Jeff,
Actual run is about 35 - 40ft, Figured it's shouldn't give me any problems, Just one of our sales guys asked the question and I couldn't put my finger on the answer
thanks
brian
I know we've gone as far as 200ft and it's worked like a charm . . . although I wouldn't reccomend it.
I had found a great geeky site once upon a time that explains the distances (and how to calculate). Can't find it now, but do some searching and suffice it to say, I am sure many of us have gone over 100' on cat5 with no problems, me included.
Curt
Trikin
Curt
Trikin
Also if you have to run greater lengths, you could use the RS-422 wiring on the AMX device and use a RS422-to-RS232 converter close to the device to be controlled. Since RS-422 is basically a "balanced" version of RS-232, the protocol will be the same (without hardware handshaking options though) and should allow you to send and receive at about 3000 ft / 1 km.
RS-485 might also work, but you have to be careful about traffic control as the transmit and receive signals run over the same 2 conductors (485+ and 485-).
- Chip
You can run low-ish speed (9600 or less) Rs232 reasonable distances (up to say 50m). However the big problem is that RS232 is very vulnerable to casuing device failure during power spikes because it is unprotected and can pass electrical disturbances from one location dirtectly in to your processor.
We have over 60 AMX systems in a university and often have problems becasue projectors are powered from different distribution points to the processor. Optical isolation fixed the issues.
At the very least, if you're running RS232 some distance, also run the power from the controller to the periperal device and run the whole system it all off a good mains filter.
John
