Locked out of Touch Panel
gtg763wgtg763w Junior Member
Hey Guys heres my problem,
I have a MVP-7500 touch panel and I accidentally unselected the "Front setup access button" so now I can't get to the setup menu by pressing the two lower buttons on the face plate to change IP addresses, etc.
Is there any other way to get to the setup menu? I've tried rebooting the firmware but I can't get a connection because the connection settings in the touch panel are not correct.
  • gtg763w,
    Reboot the panel,(Pull out Batteries if need be), then Hold your thumb on the touch screen while the panel is comming back up.(Insert the Batteries). Just keep holding your thumb on it until it goes into setup.
  • alexanboalexanbo Junior Member
    Also if it's connected to a master you can do a send_command dvTP,"'SETUP'" and that will take you to the setup page.
    Also if you know the ip address of the panel you can telnet into the panel and type setup from that interface.
  • yuriyuri Junior Member
    if you hold your finger on the touchpanel when booting and it enters setup, hold it a bit longer, it then goes into calibration :)
