Netlinx studio 2.5 wierd error
I was just starting some new code, and started to add a new DEFINE_CALL and Netlinx Studio froze and a popup box appeared with the message 'the parameter is incorrect' and wouldn't go away. The only option was to close studio. Anyone else encountered this????
I've got the same some minutes ago with creating a Function.... unfortunately I can't reproduce for reporting....
It IS reproducable..... doesn't matter if it is a new or existing code file.
Just try to type and it will crash.... Upper/lower case doesn't matter. It crashes just when typing the '(' directly after the DEFINE_FUNCTION keyword without a function name.
But I can't reproduce with DEFINE_CALL.
Had the same problem.
It seems the problems occurs when you add a new function (or Call). As you type DEFINE_FUNCTION and the help function is activated netlinx studio hangs.
A work around for me is to copy an existing function (CTRL+C) and Paste it (CTRL+V) and then change whatever you want.
Good Luck
Another was is first to write your function name and then adding the DEFINE_FUNCTION Keyword... (I think there are a LOT of ways to work around
Ryan
Ryan
I just had that same problem, but it only happens when i'm in a module file.
I am having a slightly different problem with 2.5. I upgraded to 2.5 and everything went fine. I worked on some projects in the office, then at a client's place. Now (Saturday) I'm at home and can't open ANY axi or axs file - I get "The parameter is incorrect".
I tested creating a new workspace and master source file. The new source file comes up, but the colors are weird (perhaps default?). If I try to save the file, I get an error.
The cause of these problems is my projects folder is a network drive that is available offline. When I copy a project to a physical drive, it opens fine (though the colors are still nasty), or if I create a project on a physical drive, it works fine. This will be a huge hassle if I have to copy each project to a local drive when working away from the office.
