Need some help MSP 8
ondrovic
ondrovic Junior Member
I am having some issues with the followng code can someone give me some advise
Problems:
1. Feeback for button 8 isnt wokring
2. Having to hit button 5 for the power to actually cut off
3. Button 8 ( which is source 5 needs to be input # 7)
PROGRAM_NAME='keypads'
(* System Type : NetLinx                                   *)
(* REV HISTORY:                                            *)
(*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
DEFINE_DEVICE
dvSwitcher	=	5001:4:1	/// Ada Switcher  * RS232
dvCd		=	5001:9:1	/// Denon DCM 280 * IR
dvSatM		=	5001:10:1	/// Direct TV D11
dvTuner1	=	5001:2:1	/// Z-Tuner : Zone 1 * RS232
dvTuner2	=	5001:3:1	/// Z-Tuner : Zone 2 * RS232
dviPort		=	5001:1:1	///
vdviPort	=	33015:1:1	///
dvMSP1		=	6001:1:1	/// Guest Room # 6
dvMSP2		=	6002:1:1	/// Guest Room # 7
dvMSP3		=	6003:1:1	/// Kitchen
dvMSP4		=	6004:1:1	/// Loggia
dvMSP5		=	6005:1:1	/// Pool
dvMSP6		=	6006:1:1	/// Guest Bedroom # 1
dvMSP7		=	6007:1:1	/// Guest Bedroom # 2
dvMSP8		=	6008:1:1	/// Guest Bedroom # 3
dvMSP9		=	6009:1:1	/// Guest Bedroom # 4
dvMSP10		=	6010:1:1	/// Her Master Bathroom
dvMSP11		=	6011:1:1	/// His Master Bathroom
dvMSP12		=	6012:1:1	/// Master Bedroom
dvMSP13		=	6013:1:1	/// Ocean Porch
vdvMSP1		=	33021:1:1
vdvMSP2		=	33022:1:1
vdvMSP3		=	33023:1:1
vdvMSP4		=	33024:1:1
vdvMSP5		=	33025:1:1
vdvMSP6		=	33026:1:1
vdvMSP7		=	33027:1:1
vdvMSP8		=	33028:1:1
vdvMSP9		=	33029:1:1
vdvMSP10	=	33030:1:1
vdvMSP11	=	33031:1:1
vdvMSP12	=	33032:1:1
vdvMSP13	=	33033:1:1
gdvTP		=	7000:1:1
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
INTEGER nMSP_SC_Buttons[]=
    1,	/// Tuner
    2,	/// CD
    3,	/// Sat Music ( XM )
    4,	/// Request
    8	/// Ipod
Integer nMSP_PWR_Button[]=
    5	/// Power Off
INTEGER nMSP_VOL_Buttons[]=
    6,	/// Volume UP
    7	/// Volume Down
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
DEFINE_VARIABLE
CHAR strWhPwr[18]
INTEGER nKPButton
INTEGER nKPIndex
INTEGER nKPAddress
INTEGER nZnSc[18]
INTEGER nMute[18]
INTEGER nZoneSc
CHAR strDebug[255]
(* IPOD *)
VOLATILE INTEGER TP_BUTTONS[] =     // Touchpanel button mapping array
//  CHANNEL BUTTONS / Place Holder / Function
  101, //01 Menu
  102, //02 Select
  103, //03 Play/Pause
  104, //04 Offline/Online
  105, //05 Previous<<
  106, //06 Next>>
  107, //07
  108, //08
  109, //09 List up 10
  110, //10 List up 1
  111, //11 List Down 1
  112, //12 List Down 10
  113, //13 List 1
  114, //14 List 2
  115, //15 List 3
  116, //16 List 4
  117, //17 List 5
  118, //18 List 6
  119, //19 List 7
  120, //20 List 8
  121, //21 List 9
  122, //22 List 10
  123, //23 Repeat
  124, //24 Shuffle
  125, //25 Playlist
  126, //26 Now Playing
  127, //27 List Level
  130  //28 nothing
VOLATILE INTEGER TP_FIELDS[]=  // VARIABLE TEXT BUTTONS
//Addres Codes / Place Holder / Function
  100, //01 iPod Name
  101, //02 List 01
  102, //03 List 02
  103, //04 List 03
  104, //05 List 04
  105, //06 List 05
  106, //07 List 06
  107, //08 List 07
  108, //09 List 08
  109, //10 List 09
  110, //11 List 10
  111, //12 Playing x of y
  112, //13 Artist
  113, //14 Album
  114, //15 Track
  115, //16 Time
  116, //17 Repeat
  117, //18 Shuffle
  118, //19 Play Status
  119, //20 List x of y
  120  //21 Pathway
PERSISTENT INTEGER UI_LIST[] = {10,2,0}	// See below: - not implemented in 1.0 Beta
(* All Key Pads *)
DEV dvKp[]    = {vdvMSP1, vdvMSP2, vdvMSP3, vdvMSP4,
		vdvMSP5, vdvMSP6, vdvMSP7, vdvMSP8,
		vdvMSP9, vdvMSP10, vdvMSP11, vdvMSP12,
		vdvMSP13}
(* Zone 1 *)
DEV dvKPZn1[] = {vdvMSP1, vdvMSP2, vdvMSP3, vdvMSP4,
		vdvMSP9, vdvMSP13}
(* Zone 2 *)
DEV dvKPZn2[] = {vdvMSP10, vdvMSP11, vdvMSP12}
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
([vdvMSP1,1] .. [vdvMSP1,5])
([vdvMSP2,1] .. [vdvMSP2,5])
([vdvMSP3,1] .. [vdvMSP3,5])
([vdvMSP4,1] .. [vdvMSP4,5])
([vdvMSP5,1] .. [vdvMSP5,5])
([vdvMSP6,1] .. [vdvMSP6,5])
([vdvMSP7,1] .. [vdvMSP7,5])
([vdvMSP8,1] .. [vdvMSP8,5])
([vdvMSP9,1] .. [vdvMSP9,5])
([vdvMSP10,1] .. [vdvMSP10,5])
([vdvMSP1,11] .. [vdvMSP11,5])
([vdvMSP1,12] .. [vdvMSP12,5])
([vdvMSP1,13] .. [vdvMSP13,5])
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
(* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
(* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
DEFINE_CALL 'Zone On'
    SWITCH(nZoneSc)
	CASE 1:
	    SEND_STRING dvTuner1,"'W 1 1 1',13"		/// Turn On Tuner Zone 1
	    PULSE[dvCD,1]				/// Play On CD Player
	    /// Sat Music Power On
	    DO_PUSH(gdvTP,200)				/// Request Zone 1 Connect
	    WAIT 5
		DO_PUSH(gdvTP,25)				/// Request Zone 1 Play
	    DO_PUSH(gdvTP,104)				/// I-Pod Connect
	    WAIT 10
		DO_PUSH(gdvTP,103)
	    SELECT
		ACTIVE(nKPIndex < 10):
		    SEND_STRING dvSwitcher,"'`SVLR1R0',ITOA(nKPIndex),13"
		    SEND_STRING dvSwitcher,"'`SAD0',ITOA(nZnSc[nKPIndex]),'R0',ITOA(nKPIndex),13"
		ACTIVE(nKPIndex > 9):
		    SEND_STRING dvSwitcher,"'`SVLR1R',ITOA(nKPIndex),13"
		    SEND_STRING dvSwitcher,"'`SAD0',ITOA(nZnSc[nKPIndex]),'R',ITOA(nKPIndex),13"
	CASE 2:
	    SEND_STRING dvTuner2,"'W 1 1 1',13"		/// Turn On Tuner Zone 2
	    /// Request Zone 2 Connect
	    /// Request Zone 2 Play
	    /// I-Pod Connect
	    SELECT
    ON[nKPAddress,nZnSc[nKPIndex]]
    strWhPwr[nKPIndex] = 'N'
    strDebug = 'Zone On Call Is Running'
DEFINE_CALL 'Zone Source'
    SWITCH(nZoneSc)
	CASE 1:
	    SELECT
	CASE 2:
	    SELECT
    strDebug = 'Zone Source Call Is Running'
DEFINE_CALL 'Source Function'
    SWITCH(nZoneSc)
	CASE 1:
	    SWITCH(nKPButton)
		CASE 1:		/// Tuner Next Preset
		    SEND_STRING dvTuner1,"'W 1 3 3',13"
		    BREAK
		CASE 2:		/// CD Next Track
		    PULSE[dvCD,4]
		    BREAK
		CASE 3:		/// Sat Music Next Preset
		    BREAK
		CASE 4:		/// Request Next Track
		    DO_PUSH(gdvTP,32)
		    BREAK
		CASE 5:		/// IPOD Next Track
		    DO_PUSH(gdvTP,106)
		    BREAK
	    BREAK
	CASE 2:
	    SWITCH(nKPButton)
		    SEND_STRING dvTuner2,"'W 1 3 3',13"
		    BREAK
		    PULSE[dvCD,4]
		    BREAK
		    BREAK
		    BREAK
		    BREAK
	    BREAK
    OFF[nKPAddress,nZnSc[nKPIndex]]
    WAIT 5
    strDebug = 'Source Function Call Is Running'
DEFINE_CALL 'Zone Off'
    IF(!(FIND_STRING(strWhPwr, 'N',1)))
	SELECT
		SEND_STRING dvSwitcher,"'`SRMOFR0',ITOA(nKPIndex),13"
		SEND_STRING dvSwitcher,"'`SRMOFR',ITOA(nKPIndex),13"
	SWITCH(nZoneSc)
	    CASE 1:
		SEND_STRING dvTuner1,"'W 1 1 0',13"
		BREAK
	    CASE 2:
		SEND_STRING dvTuner2,"'W 1 1 0',13"
		BREAK
	PULSE[dvCD,2]
	DO_PUSH(gdvTP,104)
    strWhPwr[nKPIndex] = 'F'
    ON[nKPAddress,5]
(*                STARTUP CODE GOES BELOW                  *)
DEFINE_START
(* Power Status MSPs *)
strWhPwr 	=	'FFFFFFFFFFFFFFFFFF'
(* MSP Modules *)
DEFINE_MODULE 'MSPMod' modMSP1  (vdvMSP1, dvMSP1)
DEFINE_MODULE 'MSPMod' modMSP2  (vdvMSP2, dvMSP2)
DEFINE_MODULE 'MSPMod' modMSP3  (vdvMSP4, dvMSP3)
DEFINE_MODULE 'MSPMod' modMSP4  (vdvMSP4, dvMSP4)
DEFINE_MODULE 'MSPMod' modMSP5  (vdvMSP5, dvMSP5)
DEFINE_MODULE 'MSPMod' modMSP6  (vdvMSP6, dvMSP6)
DEFINE_MODULE 'MSPMod' modMSP7  (vdvMSP7, dvMSP7)
DEFINE_MODULE 'MSPMod' modMSP8  (vdvMSP8, dvMSP8)
DEFINE_MODULE 'MSPMod' modMSP9  (vdvMSP9, dvMSP9)
DEFINE_MODULE 'MSPMod' modMSP10 (vdvMSP10, dvMSP10)
DEFINE_MODULE 'MSPMod' modMSP11 (vdvMSP11, dvMSP11)
DEFINE_MODULE 'MSPMod' modMSP12 (vdvMSP12, dvMSP12)
DEFINE_MODULE 'MSPMod' modMSP13 (vdvMSP13, dvMSP13)
(* MISC *)
#INCLUDE 'Queue_and_Threshold_Sizes.axi'
(* Touch Panel *)
DEFINE_MODULE 'iPort_UI' IPORT_UI1(vdviPort, gdvTP, TP_BUTTONS, TP_FIELDS, UI_LIST)
DEFINE_MODULE 'iPort COMM' IPORT_MODULE(vdviPort, dviPort)
(* System Information Strings ******************************)
(* Use this section if there is a TP in the System!        *)
    SEND_COMMAND TP,"'!F',250,'1'"
    SEND_COMMAND TP,"'TEXT250-',__NAME__"
    SEND_COMMAND TP,"'!F',251,'1'"
    SEND_COMMAND TP,"'TEXT251-',__FILE__,', ',S_DATE,', ',S_TIME"
    SEND_COMMAND TP,"'!F',252,'1'"
    SEND_COMMAND TP,"'TEXT252-',__VERSION__"
    SEND_COMMAND TP,"'!F',253,'1'"
    (* Must fill this (Master Ver) *)
    SEND_COMMAND TP,'TEXT253-'
    SEND_COMMAND TP,"'!F',254,'1'"
    (* Must fill this (Panel File) *)
    SEND_COMMAND TP,'TEXT254-'
    SEND_COMMAND TP,"'!F',255,'1'"
    (* Must fill this (Dealer Info) *)
    SEND_COMMAND TP,'TEXT255-'
DEFINE_EVENT
BUTTON_EVENT [dvKPZn1,nMSP_SC_Buttons]
    PUSH:
	nZoneSc = 1
BUTTON_EVENT [dvKPZn2,nMSP_SC_Buttons]
    PUSH:
	nZoneSc = 2
BUTTON_EVENT [dvKP,nMSP_SC_Buttons]
    PUSH:
	nKPButton = Get_Last(nMSP_SC_Buttons)
	nKPIndex = Get_Last(dvKP)
	nKPAddress = (nKPIndex + 33020)
	SELECT
	    ACTIVE(!(strWhPwr[nKPIndex] = 'N') AND nKPButton < 6):
		nZnSc[nKPIndex] = nKPButton
		CALL 'Zone On'
	    ACTIVE(strWhPwr[nKPIndex] = 'N' AND nKPButton < 6 AND nKPButton = nZnSc[nKPIndex]):
	    ACTIVE(strWhPwr[nKPIndex] = 'N' AND nKPButton < 6 AND !(nKPButton = nZnSc[nKPIndex])):
		CALL 'Zone Source'
    HOLD[20]:
	SWITCH(nZoneSc)
	    CASE 1:
		SWITCH(nKPButton)
		    CASE 1:	/// Tuner Previous Preset
			SEND_STRING dvTuner1,"'W 1 3 4',13"
			BREAK
		    CASE 2:	/// CD Next Disc
			PULSE[dvCD,50]
			BREAK
		    CASE 3:	/// Sat Music Previous Preset
			BREAK
		    CASE 4:	/// Request Next Album
			BREAK
		    CASE 5:	/// IPod Previous Track
			IF(nZnSc = 5)
			    nZnSc[nKPIndex] = 7
			DO_PUSH(gdvTP,105)
			BREAK
	    CASE 2:
		SWITCH(nKPButton)
			SEND_STRING dvTuner2,"'W 1 3 4',13"
			BREAK
			PULSE[dvCD,50]
			BREAK
			BREAK
			BREAK
		    CASE 5:	/// IPod
			IF(nZnSc = 5)
			    nZnSc[nKPIndex] = 7
			DO_PUSH(gdvTP,105)
			BREAK
BUTTON_EVENT[dvKP,nMSP_VOL_Buttons]
    PUSH:
	nKPButton = Get_Last(nMSP_VOL_Buttons)
	SWITCH(nZoneSC)
	    CASE 1:
		SWITCH(nKPButton)
		    CASE 1:
			SELECT
				SEND_STRING dvSwitcher,"'`SVLUPR0',ITOA(nKPIndex),13"
				SEND_STRING dvSwitcher,"'`SVLUPR',ITOA(nKPIndex),13"
			PULSE[nKPAddress,6]
		    CASE 2:
			SELECT
			    SEND_STRING dvSwitcher,"'`SVLDNR0',ITOA(nKPIndex),13"
			    SEND_STRING dvSwitcher,"'`SVLDNR',ITOA(nKPIndex),13"
		    PULSE[nKPAddress,7]
	    CASE 2:
		SWITCH(nKPButton)
		    CASE 1:
			SELECT
			PULSE[nKPAddress,6]
		    CASE 2:
			SELECT
		    PULSE[nKPAddress,7]
    HOLD[2,REPEAT]:
	SWITCH(nZoneSC)
	    CASE 1:
		SWITCH(nKPButton)
		    CASE 1:
			SELECT
			PULSE[nKPAddress,6]
		    CASE 2:
			SELECT
			PULSE[nKPAddress,7]
	    CASE 2:
		SWITCH(nKPButton)
		    CASE 1:
			SELECT
			PULSE[nKPAddress,6]
		    CASE 2:
			SELECT
		    PULSE[nKPAddress,7]
BUTTON_EVENT[dvKp,5]
    PUSH:
	CALL 'Zone Off'
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
[vdvMSP1,5]	=	(strWhPwr[1]	= 'F')
[vdvMSP2,5]	=	(strWhPwr[2]	= 'F')
[vdvMSP3,5]	=	(strWhPwr[3]	= 'F')
[vdvMSP4,5]	=	(strWhPwr[4]	= 'F')
[vdvMSP5,5]	=	(strWhPwr[5]	= 'F')
[vdvMSP6,5]	=	(strWhPwr[6]	= 'F')
[vdvMSP7,5]	=	(strWhPwr[7]	= 'F')
[vdvMSP8,5]	=	(strWhPwr[8]	= 'F')
[vdvMSP9,5]	=	(strWhPwr[9]	= 'F')
[vdvMSP10,5]	=	(strWhPwr[10]	= 'F')
[vdvMSP11,5]	=	(strWhPwr[11]	= 'F')
[vdvMSP12,5]	=	(strWhPwr[12]	= 'F')
[vdvMSP13,5]	=	(strWhPwr[13]	= 'F')
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
thanks
