Fun with compliers
cbailey
So today I re-learned the important lesson of not referencing the zero memory location of an array. Boiled down here is my code:
If you run this you will notice the second test will fail unexpectedly for it is the same as the first test with its arguments switched.
If you adjust the code to make the FOR loop read "FOR(i=1;i<=10;i++)", then both tests will succeed as expected.
Does anyone know why the compiler would behave in this manner? Is there a fix for this or should I just never forget the lesson I re-learned (again) today?
DEFINE_DEVICE
dvTP = 10001:1:0
dvDEBUG = 33333:1:0
DEFINE_VARIABLE
INTEGER numbers[10] = {1,2,3,4,5,6,7,8,9,10};
DEFINE_FUNCTION INTEGER isInSet(INTEGER nInput){
LOCAL_VAR INTEGER i;
FOR(i=0;i<=10;i++){
IF(nInput == numbers[i]){
RETURN 1;
RETURN 0;
DEFINE_EVENT
BUTTON_EVENT[dvTP,1]{
PUSH:{
IF( isInSet(1) AND (2 > 1) ){
SEND_COMMAND dvDEBUG, "'Test version 1 succeeds!'";
ELSE{
SEND_COMMAND dvDEBUG, "'Test version 1 fails.'";
IF( (2 > 1) AND isInSet(1) ){
SEND_COMMAND dvDEBUG, "'Test version 2 succeeds!'";
ELSE{
SEND_COMMAND dvDEBUG, "'Test version 2 fails.'";
I think the lesson here is - never reference zero in the array. All the manuals essentially say: "NetLinx arrays start at 1 - not zero like most programming languages." You may have found a compiler bug, and might be worth reporting - but complying with the essential NetLinx rules is a "must".
cbailey wrote:Does anyone know why the compiler would behave in this manner? Is there a fix for this or should I just never forget the lesson I re-learned (again) today?
Did you try reversing the tests (so that you do 2 before 1) to see if this has an impact?
In principle there should not be a difference in this case but accessing element 0 of an array probably gives an UNDEFINED behaviour... and then all bets are off as to what can happen. Some CPU vendors do have a serious statement about UNDEFINED stuff (AMD for example).
I am mentioning the first question because in my experience, it seems to me repeatedly accessing the 0th element that causes problems, not just once.
Fred -
If I reverse the order of the tests in the code I get the same result of version 2 failing and version 1 succeeding (although the debug notifications show up in reversed order).frthomas wrote:Did you try reversing the tests (so that you do 2 before 1) to see if this has an impact?
It seems that for some reason the compiler doesn't like version 2. -
No further ideas. It's not clear to me what the side effects of accessing element 0 can be. Undefined looks to me like the answer here :-)
The fix, well, don't access the 0th element of an array. That actually does add something to the system log, so it's easy to catch.
Fred
