UPC20+ in europe?
bob
bob Independent Programmer
Has anyone used the UPC20+ in europe with 220volts? According to its specs it should be possible but just to make sure... Usage should be for simple turning on/off power amps.
Bob.
  • pdabrowski
    pdabrowski Aussie Guy
    the UPC-20 is sold in Australia where the working voltage is 230-240 volts.
    The internal relay contacts are rated to 250 volts IIRC, so you should be ok.
    Just make sure that the internal voltage switch is set to 240 volts and not 110 as shipped unlike one of my installers who "forgot"!
  • bob
    This is what I thought reading the specs but wasn't sure. Thanks much!
