Multidimensional Structure What's Wrong With This Picture
I have my structure set up just like the example in the programming manual on page 175
I am trying to make a multidimensional structure
Here is my code
DEFINE_DEVICE
dvTP_1=128:1:1
DEFINE_CONSTANT
nAudioZoneMax=6 //Value To Say if room number is greater than nAudioZoneMax, it is a surround zone - Will equal the number of Audio zones
nTotalZoneMax=10 //Total number Of Zones
nAudioSourceTotal=6
INTEGER nBtnArray_RoomNav[]={3001,3002} //Array For Navigation Button Numbers
DEV dvAllTP[]={dvTP_1} //Array For Touchpanels
INTEGER nBtnArray_AudioZoneNav[]={2001,2002,2003}
INTEGER nBtnArray_SurroundZoneNav[]={2101,2102,2103}
DEFINE_TYPE
STRUCTURE _PanelStruct
INTEGER nRoomSelected //Keeps Up With What Room Which Panel Is On
STRUCTURE _AudioZoneStructure
CHAR cZoneName[50]
****HERE IS THE AREA OF QUESTION*****
_AudioZoneSourceStructure AudioSource[6]
INTEGER nZonePowerStatus
STRUCTURE _AudioZoneSourceStructure
INTEGER nPowerStatus
INTEGER nUseStatus
DEFINE_VARIABLE
//Room Navigation
INTEGER nRoomNavButtonFactor = 3000 //Value to subtract from the Button Press To get some factor
INTEGER nSurroundButtonFactor= 2000
INTEGER nAudioZoneButtonFactor= 2100
INTEGER nPanelNum
INTEGER nRoomVar
_PanelStruct Panel[1]
INTEGER SourceInc //Value To Run Through Source Status To Do Button Feedback
_AudioZoneStructure AudioZone[nAudioZoneMax]
_AudioZoneSourceStructure AudioSource[nAudioSourceTotal]
DEFINE_LATCHING
DEFINE_MUTUALLY_EXCLUSIVE
DEFINE_START
DEFINE_EVENT
BUTTON_EVENT [dvAllTP,nBtnArray_RoomNav]
PUSH:
nPanelNum=GET_LAST(dvAllTP) //Gets Which Panel Press Came From
nRoomVar=GET_LAST(nBtnArray_RoomNav) //Gets Which Button Got Pressed
OFF[dvAllTP[nPanelNum],nBtnArray_RoomNav]
OFF[dvAllTP[nPanelNum],nBtnArray_AudioZoneNav] //Clear Button Status
OFF[dvAllTP[nPanelNum],nBtnArray_SurroundZoneNav] //Clear Button Status
Panel[nPanelNum].nRoomSelected=nRoomVar //Tells which room a particular panel has selected
IF(Panel[nPanelNum].nRoomSelected<nAudioZoneMax)
****BELOW IS ANOTHER THE AREA OF QUESTION*****
FOR(SourceInc=1;SourceInc<=nAudioZoneMax;SourceInc++)
[dvAllTP[nPanelNum],nBtnArray_AudioZoneNav[SourceInc]]=AudioZone[Panel[nPanelNum].nRoomSelected].AudioSource[SourceInc].nUseStatus
On[dvAllTP[nPanelNum],nBtnArray_RoomNav[nRoomVar]]
I am trying to update a source button status based on which source is in use in that given room.
When I Compile i get "left side of [.nUseStatus] must be a Structure Type."
It looks exactly like the manual's code to me...I dont know what is up..
Rolo
  • Reese JacobsReese Jacobs Junior Member
    STRUCTURES are fun
    Rolo,
    Two things:
    1. To fix the compile error, simply move the structure definition for STRUCTURE _AudioZoneSourceStructure before the structure definition for STRUCTURE _AudioZoneStructure. The compiler seems to have a bit of a forward reference problem in this case. Defining the embedded structure prior to its declaration and use in the second structure fixes the compile problem.
    2. The independent declaration of _AudioZoneSourceStructure AudioSource[nAudioSourceTotal] (just prior to the DEFINE_LATCHING section) seems redundant and is probably not what you want since AudioSource is also an array embedded within one of your structures. Best case, it is confusing. Worse case, it is not needed.
    Hope this helps.
    Reese
