AXU MTP Info required
Does anyone have connection info for the AXU MTP monochrome touch panel? I have the axlink connection but I am told that there is RS 232 as well, but I cannot find this info on the AMX website, thanks.
The AXU-MTP is a quite old device. AFAIK it is similar with the AXU-MLC and it would have the Phoenix connector for AXlink. What I can remember is something about a connector onboard for RS232 which is not a 9pin DSUB, but I'm not sure.
On the AMX homepage, go to TECH CENTER -> TECHNICAL DOCS -> ARCHIVED MANUALS and look for the AXU-MLC in the Touch Panel section.
Kind regards,
- Chip
