TPDesign4 Button Passwords?
Button General Properties - Password Protection
Password Protection ? This option allows you to apply password protection to the selected button(s).
You can set up to four passwords per panel; use this drop-down list to select which of four possible passwords to apply to the selection (none, password 1, password 2, password 3, or password 4).
How do you "set" these passwords? The dropdown menu just allows me to select "password 1", "password 2", etc. I looked in the help files and the only description I could find of this feature is above.
2) Press passwords and set "Password #" to whatever
3) Voila!
EDIT: Yay, they work as expected (no channel event until the password is correctly entered). If you want to password protect a couple buttons (user login buttons) without changing your code, this is a nifty feature. The main drawback being you have to enter a set of passwords for each panel.
It's an old module, so I can't promise some of the code isn't a little on the dark side
Hi Dave,
Is it possible you can send me the code aswell, Or put it in tips and tricks for all to use.
Thank You
