iTunes Control
2»
  • bobbob Independent Programmer
    Check out girder, it has a plugin to iTunes running on the same PC and then from girder you can output anything either on RS232 or TCP/IP based on iTunes events (like track change and then output track info)... You can also control iTunes from girder.
