Sauna Controls
Does anybody has a good solution for sauna controls with Netlinx? I am looking for a TEMP display, On and Off buttons and if possibly a heating set point up and down buttons. In the past, I used to program the ON and Off buttons out of a relay output. However, as clients get more demanding, they also want to know the Temperature and raise or lower the heating setpoint. Any ideas?
Ricardo
ACE Expert
Ricardo
ACE Expert
How about something like this SAUNA CONTROLLER? It's IR capable. Maybe learn the codes with an IRIS and interface with Netlinx that way. No feedback regarding temperature, but if they're in the sauna they should be able to read and control it there with the supplied Sauna-proof remote that comes with it. I would imagine you'd only want to adjust set points and start the unit via an AMX touchpanel if you're going to warm it up so that it's ready when you get in. Once they're inside, they would use the Sauna controller or again, the supplied remote.
By the way Ricardo, how did you guys fare with that plane crash at Palomar a few weeks back. I thought about you when I heard the news but you've posted on the forum since then so I figured you were O.K.
-- John
--John
Jandy will not control a sauna directly. Depending on the type you might be able to use a Jandy Relay to turn pwoer on or off to the device. The relays can handle 220V and up to a 3HP motor. You have to watch the loads or you will burn up the relay. If you have Lutron some of their devices can also hadle up to 1000 watts.
