Doorbell Through AMX System........
Impaqt
Just pulled an Intellinet system and replaced with AMX.... THe one complaint the client has is the lack of a Doorbell... Go figure...
ANyway, I think this could be simple.... Run the trigger into an IO on the NI-2000, Have the AS-16 Store the Current Input/Volume Matrix as a Preset. Move to a Doorbell Preset. Play a WAV File... Then recall the Preset we set in step 1.
Seems logical to me right??? Heres the question. WHat do I use to generate the Wav file. Needs to be fast and triggerable with a simple contact or RS-232 string....
CFSound
I recommend checking out CFSound. I used CFSound as part of a phone interface solution and it worked great. You can trigger from contact closure and you have complete control with a simple RS-232 protocol. Good bang for the buck.
http://cfsound.com/index_CFSound.asp -
Just came across one of these while upgrading a system, it was in place, so I did not change the wav files. Controlled just as stated.
Existing AS-16 - saved preset, turned up volume, played wav, waited for the RS232 feedback from this piece that said wav file had finished playing !!! - then set the preset back.
Very nice.
http://www.auroramultimedia.com/web/?section=products&product=ios
Bill -
Ended up ordering this http://www.pricom.com/Trains/DreamPlayer.html
Pretty cool piece. Uses a SD card to store the WAV Files for the client can even change the Rings if he's halfway computer savy....
I'll let ya know how it works out.
