Controll an existing DM-MD16X16
Hello,
I have an Install i need to upgrade to an AMX Controll system with an existing DM-MD16X16 video Matrix.
Has someone controlled already some experience with controlling one of them ? i found no commands in the usermanual.
Thanks a lot.
Kind regards
The other thing a lot of people do is use a small Crestron master and write a small program to handle an RS232 or IP connection from the AMX master to control the DM.
Not true, or at least not documented widely, here is a snippet that I copied from another medium:
Set AVUROUTE [inputSlot] [outputSlot] for A/V/USB, SetAVROUTE [I] [o] for A/V only, SETVIDEOROUTE, SETAUDIOROUTE.
Notes
1- This doesn't update the front panel status and isn't intended for normal operation
2- The output SLOT number, not the output number, e.g. output 1 on a 8x8, 16x16 is 17 IIRC
3- Input 0 can be used to route no input to an output
