IR file for Cisco DTA 170HD?
Does anyone know what IR file is most compatible with the Cisco DTA 170HD digital settup box tuner?
I've checked https://trade.amx.com/Net/Inconcert/Devices/InConcertMainPage.aspx, but haven't found any close matches.
The remote has "HDA-IR2.2" printed on the back.
I've tried a couple of the other settop boxes files, and the SCIENT08.IRL (listed under Scientific Atlanta) one mostly works. It doesn't have the correct 45:Menu/Cursor Up (sends a signal but box doesn't respond), and 24:Volume Up/25:Vol Down/26:Volume Mute toggle (no LED pulse, so probably not defined in the file) I can live with this one, but was hoping there was a more compatible one.
Unfortunately, I don't have an IR capture box (AMX or otherwise) to create my own.
Normally I'd link to this but I don't want to host the file forever.
THIS IS ONLY PART OF THE DATA. Go get the rest at the site.
IR Code Set Cisco DTA 170HD Digital Transport Adaptor - Set # 5577
From GLOBAL CACHE CONTROL TOWER IR DATABASE (FREE)
https://irdb.globalcache.com/
Note that the SENDIR segment is for use with Global Cache equipment.
The 4-digit group data in quotes is the AMX compatible hex code.
function, code1, hexcode1, code2, hexcode2
"CHANNEL DOWN","sendir,1:1,1,58000,1,1,193,193,48,144,48,144,48,48,48,144,48,144,48,48,48,144,48,144,48,144,48,144,48,48,48,48,48,48,48,144,48,48,48,48,48,144,48,48,48,48,48,48,48,48,48,144,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0898",,
"CHANNEL UP","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,145,48,48,48,145,48,145,48,145,48,48,48,48,48,48,48,145,48,48,48,48,48,48,48,145,48,48,48,48,48,48,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0091 0030 0898",,
"CURSOR DOWN","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,145,48,145,48,48,48,145,48,48,48,48,48,48,48,48,48,145,48,48,48,48,48,48,48,48,48,145,48,48,48,145,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0091 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0091 0030 0091 0030 0898",,
"CURSOR ENTER","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,48,48,48,48,145,48,145,48,48,48,48,48,48,48,48,48,145,48,48,48,48,48,145,48,145,48,48,48,48,48,145,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0091 0030 0091 0030 0898",,
"CURSOR LEFT","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,145,48,145,48,48,48,48,48,48,48,48,48,48,48,48,48,145,48,48,48,48,48,48,48,48,48,145,48,145,48,145,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0091 0030 0091 0030 0091 0030 0898",,
"CURSOR RIGHT","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,48,48,48,48,145,48,48,48,48,48,48,48,48,48,48,48,145,48,48,48,48,48,145,48,145,48,48,48,145,48,145,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0898",,
"CURSOR UP","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,48,48,145,48,48,48,48,48,48,48,48,48,48,48,48,48,145,48,48,48,48,48,145,48,48,48,145,48,145,48,145,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0091 0030 0898",,
"DIGIT 0","sendir,1:1,1,58000,1,1,193,193,48,145,48,145,48,48,48,145,48,145,48,145,48,48,48,48,48,145,48,145,48,48,48,48,48,48,48,145,48,48,48,48,48,48,48,145,48,145,48,48,48,48,48,145,48,2200","0000 0048 0000 0018 00C1 00C1 0030 0091 0030 0091 0030 0030 0030 0091 0030 0091 0030 0091 0030 0030 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0030 0030 0091 0030 0030 0030 0030 0030 0030 0030 0091 0030 0091 0030 0030 0030 0030 0030 0091 0030 0898",,
(more, but too much to post. Go get it.)
