Barco Clickshare api ssl/https 🤔
Hello guys
I am blocked on a Barco clickshare cse800 !
I only need to change one setting from one to two screen.
There is an api but only ssl (https).
Manual here https://www.barco.com/services/website/en/TdeFiles/Download?FileNumber=R5900056&TdeType=1&Revision=01&ShowDownloadPage=False
Does someone know how to connect to it via https? I looked everywhere and didn't find a hint!!
Thanks a lot in advance!
Best regards
  • HARMAN_icraigie
    HARMAN_icraigie Technical Trainer II, Harman Professional University
    TLS_CLIENT_OPEN
    Opens a port for TLS communication with a remote device.
    Syntax:
    integer TLS_CLIENT_OPEN(LocalPort, hostname, port, mode)
    Parameters:
    LocalPort- A user-defined (non-zero) integer value representing the local port on the client machine to use for this conversation. This local port number must be passed to TLS_CLIENT_CLOSE to close the conversation.
    hostname - The host name or IP address of the remote host.
    port - The connecting port on the remote host, usually port 443 for standard HTTPS connections.
    mode - 0: TLS_VALIDATE_CERTIFICATE (perform certificate validation), 1: TLS_IGNORE_CERTIFICATE_ERRORS (connect to the remote site while ignoring certificate errors or mismatches)
    Returns:
    This function returns 0 is all parameters are accepted, or a positive value indicating the offending parameter if there is an error.
    Example:
    TLS_CLIENT_OPEN(5000, '192.168.0.1', 443, 0)
    Note - when using mode = TLS_VALIDATE_CERTIFICATE the server certificate must be imported into the NetLinx masters CA.
  • MLaletas
    MLaletas Junior Member
    As Ian said use TLS, I use mode of 1 and it works with no problem the port number is 4001 now, and you will need to do basic authentication.
  • Thanks guys!!! Can't wait to test it out! Thanks a lot
  • Sorry for bothering you again but I fail miserably to make it work!
    I can now connect to it with the TLS mode 1.
    But I struggle with the basic authentification and header.
    I never have an answer from the device.
    I tried a GET command with:
    SendCommand ("'GET /v1.0/OnScreenText/Location HTTPS/1.1',13,10")
    SendCommand ("'Authorization: Basic ',fnBase64('integrator:integrator'),13,10,13,10")
    The SendCommand function is just for connecting first and stacking commands:
    DEFINE_FUNCTION SendCommand(CHAR sCmd[]){
    IF(nIpConneted)
    SEND_STRING dvIP, sCmd
    ELSE {
    PushStack(sCmd);
    ConnectIP();
    Can someone help me ? Thanks a lot in advance!
    Best Regards
  • HARMAN_icraigie
    See if it works with changing the HTTPS/1.1 to HTTP/1.1 as the HTTP commands are independent from TLS
    https://github.com/hypery2k/owncloud/issues/60
  • Thanks a lot! now I have an Answer! thanks !! :D
  • Hella again :s
    Get works perfectly but I can't set a Parameter. I tried many hours.
    I tried many ways, even the example in the API manual from barco...
    Did someone already made it works ?
    Thanks a loooooot !!
    When i send this request : // this is the output from what I send.
    POST /v1.0/OnScreenText/Location HTTP/1.1
    Authorization: Basic aW50ZWdyYXRvcjppbnRlZ3JhdG9y
    Content-Length: 19
    Content-Type: application/json; charset=utf-8
    { "value": "test" }
    I Get the answer :
    HTTP/1.1 404 Not Found
    X-Powered-By: Express
    Content-Length: 59
    Date: Tue, 08 Jan 2019 16:49:09 GMT
    Connection: keep-alive
    "status": 404,
    "message": "Resource does not exist"
  • MLaletas
    first thing is I dont see the host portion of the header (Host: IP_ADDRESS:4001). Add that in and see where that gets you
  • Thanks for the answer.
    I tried but nothing changes.
    And it works with the GET. should be the same as the PUT no ?
    Thanks a lot !
    Host: 192.168.2.68:4001
    Content-Length: 17
    {"value": "test"}
