RMS Version 4.6.7 RmsApi.axi file vs. a structure named "devices"
I just discovered that doesn't work. It causes a compile error in the RmsApi.axi file. I had to rename my structure to get it to work.
Hi @fogled@mizzou, do you mind sharing an example of your code and the compiler error?
Thanks for your patience, I've got a sample rolled up in a ZIP file but can't figure out how to upload files to the forum anymore. Here's a link to the Zip file on a BOX account... https://missouri.box.com/s/y794jsjaiusg4nfli28rz32errrb6ei7
