DEVLEV issue
I am trying to trigger a level event of a series of different panels using the same level number and have seen that a DEVLEV array may do the trick for me, but for some reason I cannot get the event to trigger. See below for the code:
PROGRAM_NAME='Hull Business Centre'
DEFINE_DEVICE
TP_Room_0 = 10000:1:1 // iPad Ver 2
TP_Room_1 = 10001:1:1 // iPad Ver 2
TP_Room_2 = 10002:1:1 // iPad Ver 2
DEFINE_CONSTANT
INTEGER VOLUME_AC_IN_LEVEL = 59
DEVLEV dlvTPACVol[3] =
{TP_Room_0, VOLUME_AC_IN_LEVEL},
{TP_Room_1, VOLUME_AC_IN_LEVEL},
{TP_Room_2, VOLUME_AC_IN_LEVEL}
DEFINE_EVENT
LEVEL_EVENT[dlvTPACVol] // AC mic volume level change
local_var integer nACZoneVolTriggered
send_string 0, 'hello'
nACZoneVolTriggered = get_last(dlvTPACVol)
What am I doing wrong?
  • zack.boydzack.boyd Smacks Keyboard Repeatedly
    Though I don't know why this doesn't work(and I did confirm it does not work), I feel like I've been tripped up by it before in my earlier days.
    My usual MO is to create an array of panels, then reference channels/levels individually. So in this instance:
    [I]PROGRAM_NAME='Hull Business Centre'[/I]
    [I]DEFINE_DEVICE
    TP_Room_0 = 10000:1:0 // iPad Ver 2
    TP_Room_1 = 10001:1:0 // iPad Ver 2
    TP_Room_2 = 10002:1:0 // iPad Ver 2
    DEFINE_CONSTANT
    DEV dvPanels[3] = {TP_Room_0,TP_Room_1,TP_Room_2}
    DEFINE_EVENT
    LEVEL_EVENT[dvPanels,VOLUME_AC_IN_LEVEL] // AC mic volume level change
    nACZoneVolTriggered = LEVEL.VALUE
    }[/I]
  • IVCBenIVCBen Junior Member
    Hi Zack.
    Thanks for your reply, that had done the trick and at least I now know l wasn't doing anything particularly wrong with my method, it just doesn't work.
    Another perculiar issue I have now come accross is that if I use the code from above, but if I combine the virtual devices with the real ones and then point the level event at the new virtual device array it does not trigger anything.
    DEFINE_DEVICE
    vdvTP_Room_0 = 33000:1:0 // vtp 1
    vdvTP_Room_1 = 33001:1:0 // vtp 2
    vdvTP_Room_2 = 33002:1:0 // vtp 3
    define_combine(vdvTP_Room_0, TP_Room_0)
    define_combine(vdvTP_Room_1, TP_Room_1)
    define_combine(vdvTP_Room_2, TP_Room_2)
    DEFINE_CONSTANT
    //DEV dvPanels[3] = {TP_Room_0,TP_Room_1,TP_Room_2}
    DEV vdvPanels[3] = {vdvTP_Room_0, vdvTP_Room_1, vdvTP_Room_2}
    DEFINE_EVENT
    LEVEL_EVENT[vdvPanels, 0]
    send_string 0, 'hello2'
    button_event[vdvPanels, 0]
    push:
    send_string 0, 'button pushed'
    The button pushing works fine though...
    Try adding:
    SET_VIRTUAL_LEVEL_COUNT(vdvTP_Room_0,60)
    SET_VIRTUAL_LEVEL_COUNT(vdvTP_Room_1,60)
    SET_VIRTUAL_LEVEL_COUNT(vdvTP_Room_2,60)
