The best notebook computer for field programming
What notebook do you like for field programming?
It is time to update my old core 2 duo boat anchor and was wondering what do others use.
It is hard to get rid of my old notebook since it has a db9 connector that will always connect to these old systems I run into. How compatible are the new thin notebooks using USB to 232 adapters?
On the DB9 port thing. I begrudgingly gave up on that a while back and have gone with the rs232 USB dongle. It works just fine. The one thing, however, that can be annoying is, where when you have a built-in DB9 port, it's alway ports 1 and/or 3, with the USB the ports can and do change.
So, when using one, you add the step of opening up Device Manager and seeing what port ID the USB serial adapter pulled up today; this because the apps we use cannot tell us where it is, they only give us a list of possible ports. But, like most things, it just becomes part of the muscle memory of doing work.
So, moving to a machine without a DB9 is an adjustment. But, it does work and is not too big a deal.
Lastly, (and I'm sure there are those here who would roll their eyes and disagree) I'd see about running Windows 7 Pro. I have machines of higher OSs. Win 7 has almost zero issues with drivers/crashes/etc... If you go Win 10, there is just some things that don't work for whatever reason - or their flaky.
Current one is a Toshiba Satellite Z30-A and I've found another with similar interfaces and size/spec
HP EliteBook 830 http://h20386.www2.hp.com/AustraliaStore/Merch/Product.aspx?id=V6D66PA&opt=&sel=NTB
Core i5-6300u
8Gb Ram
256Gb SSD
14" HD Screen (1920x1080)
USB3 ports
VGA
Display Port
RJ45 on board (this is a show stopper if the notebook doesn't have one!)
RS232 is ok. I have a method to get my USB adapter working on Win10 (connect the converter, access device manager and downgrade the driver to a working one.) I know you aren't using Win10 for reasons, but since Win8 there has been the Win+X key shortcuts to access all of the "superuser" panels (Network interfaces, device manager, computer manager, classic control panel etc..) and this alone has been worth the move to Win10.
Thanks for this. I'm sure I'll scootch on up at some point. I'm the classic "Late Adopter" Being an old recording studio audio engineer, I tend to not be so enamored by the latest-greatest bleeding edge shiny new toys. I tend to be very production oriented and I can get my work done with my current gear, I tend to stick with it. But, I'm usually forced to move along at some point.
