Elk M1G Firmware Issue with AMX Duet Module
The most recent panel firmware for the Elk M1 (M1/EZ8 Control Firmware Version 5.3.10 (released 7/11/2016)) will not work properly with the AMX Duet module. You will need to roll back the Elk panel firmware to version 5.3.0 and life will be good again. Versions prior to 5.3.0 have a problem with Windows 10. Some Elk tech support people know this but not all. Hope this helps someone.
