DGX16 Dev 5002 doesn't come online after firmware update
syslock
in AMX Hardware
After upgrading DGX master(1.4.76) and switcher(2.0.4) firmwares,
Device 5002 doesn't come online when AMX Lan authentication is set.
Diag log
Diag log
[COLOR=#212121][FONT=Helvetica Neue][SIZE=13px] Line 1982 (16:04:00.085):: Closing connection to ::1 due to username/password authentication failure; Sys=2 Dev=5002 Line 1983 (16:04:00.085):: CICSPTCP Rx connection to ::1 (socket=110, idx=13)has been closed locally or by peer, byteRead=0, errno=0 Line 1984 (16:04:00.085):: CICSPTCP:Run() idx=13 exiting, m_bExitRun=2! Line 1985 (16:04:00.100):: CICSPTCP::ShutdownICSPTCPTasks(),bExitRun=2, iSocket=110 (idx=13), shutdownCnt=1 Line 1986 (16:04:00.100):: Closed Socket Connection socket=110 addr=::1 index=13 Line 1987 (16:04:00.100):: No session to clear for this connection Line 1988 (16:04:00.100):: CIPConnectionManager::ProcessICSPPacket msg destined for outside but no socket exists iIndex=13 wCommand=$FF00 wCommand+2=$0900 Line 1989 (16:04:00.100):: IcspTcpTransport.diconnect: closing socket Line 1990 (16:04:00.460):: Memory Available = 944332800 <98304> Line 1991 (16:04:02.600):: IcspDeviceStack.run() calling transport::Connect() Line 1992 (16:04:02.600):: IcspTcpTransport::urlConnect(localhost) Line 1993 (16:04:02.600):: Master accepted connection. Line 1994 (16:04:02.694):: Accepted connection:socket=110 addr=::1 port=45783 Line 1995 (16:04:02.694):: Memory Available = 944316416 <16384> Line 1996 (16:04:02.694):: CICSPDatabase::SetAccessToken: Line 1997 (16:04:03.600):: Closing connection to ::1 due to username/password authentication failure; Sys=2 Dev=5002 [/SIZE][/FONT][/COLOR]
Bump
Anyone -
The one and only time I've ever seen something like this was when the integrated controller came online as a virtual device (in the 32000s) I was rather surprised by this. I did the "right-click / assign a new device ID" and the problem has never resurfaced.
What does tech support say? -
I've only seen it happen once with a DGX but it my case it was stuck in OS mode so it wouldnt load 5002, after some commands sent to terminal that tech support gave me we got it back up and running. With DVX's Ive seen this a good bunch, normally unplugging power and letting it sit for a couple minutes resolves it, only once has that not worked and it had to go into service.
Did you change default password for user "administrator"? I would revert it back to "password" and see if 5002 can login.
Had this problem when updating firmware when swapping I/O cards from older DGX to newer 100 series and thanks to support, I have fixed it. It was caused because the cards needed to be firmware updated too or the 5002 goes offline. Might be the same issue or not...
The process is as follows:
Remove all I/O cards ( if has audio injector/extractor card then leave in then leave these in as not hot swapable)
Reboot DGX
Wait for 5002 to come online (in online tree)
Replace all I/O Cards
Firmware update Switcher even if the latest and it will update the I/O Cards.
Like I said - might not be the same thing...
