2N intercom door lock AMX
nikhil
Hi I want to control 2N door intercom from AMX for door opening and closing.
The commands are [url]HTTP://ip_address/enu/lockstate.XML.p?lockXstate=Y[/url]
where x is which lock and y is on or off
This command when I am putting in my web browser the door lock is working. But when I am using it for AMX it is not working. I am sure the port is 80 because when I am putting :80 last it's working when I am putting other port numbers like 8080 or 443 it will not.
Anybody experienced this type of problem?
You are dealing with the http protocol so there might be something happening in the exchange between the browser and device you aren't replicating in code.
Run a wireshark on your pc while doing the activity and see exactly what is going on. Remember that just opening a socket to that address is probably not enough to tell the device what you want. it might just be as simple as sending the usual request headers. There is a lot of other info from other programmers here in dealing with http control that will get you down the right path. -
Post some code where you are sending the commands.
