The method of syncing buttons state
f0ghuaf0ghua Junior Member
I am wondering what's the best method to keep a button state sync with the actual state. I did as the following:
DEFINE_CONSTANT
CHAN_LIGHT_ROOM = 1
MAX_LIGHT_NUM = 4
DEFINE_VARIABLE
volatile dev gDvTps[TP_MAX_PANELS] = {dvTP1, dvTP2}
long TL_TP = 1 // the global timeline, used to sync the panel button state and so on
long gTLTPSpacing[1] = {250}
integer lightState[MAX_LIGHT_NUM]
DEFINE_START
TIMELINE_CREATE(TL_TP, gTLTPSpacing, 1, TIMELINE_RELATIVE, TIMELINE_REPEAT)
TIMELINE_EVENT[TL_TP]
    [gDvTps, CHAN_LIGHT_ROOM] = lightState[CHAN_LIGHT_ROOM]
As you see, the lightState array collects all the status of the lights in a DATA_EVENT block. It works, but still have problem. If the AP which links with TPcontrol and central controller powers off and on, all button states lost. even I push the button again to change state, no feedback on tpcontrol.
I think the problem maybe relate to the lightState gather code, but I still want to make sure whether my method is right. Please give me your advice.
    Where are you starting the timeline?
  • f0ghuaf0ghua Junior Member
    ericmedley wrote: »
    Sorry, I missed the DEFINE_EVENT line before the TIMELINE_EVENT. The timeline start at DEFINE_START section, it keeps looping as executing in DEFINE_PROGRAM.
    [FONT=Arial, Helvetica, Verdana, sans-serif]try putting parens around the last part. [/FONT]LIGHT_ROOM] = (lightState[CHAN_LIGHT_ROOM])
  • a_riot42a_riot42 AMX Wizard
    Not sure if I understand, but channel feedback won't activate unless the state has actually changed. So if the master sets a channel to ON, the only way it will do it again is if the channel goes OFF first. It won't bother trying to turn a channel on that it thinks is already on. It won't update channels on a touch panel automagically, you have to do it in programming.
    Paul
  • TonyAngeloTonyAngelo Code Monkey
    a_riot42 wrote: »
    Paul
    In other words, you need to do it in the online data_event of the touch panel.
