Which is the best IR learning unit available.
I want to purchase an IR learning unit which can generate files that can be used for AMX and others. I know there are softwares which can convert to other IR file versions but IRIS is not very user friendly due to the serial connection, etc. How about iTach units from Global cache. Here are a few other options that i have found.
http://www.engo.com/IRLearner.aspx
http://www.ebay.com/itm/Crestron-CSP-LIR-USB-IR-Learner/181824881969?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29981%26meid%3Ddccfdb1f49be489ba5c7fd929e8dfde8%26pid%3D100011%26rk%3D1%26rkt%3D2%26sd%3D151706489366
Let me know which units you guys are using currently.
http://www.rticorp.com/ir-pro-professional-infrared-capture-system.html
http://www.usbuirt.com/
Eric, what software are you using to capture the codes with your USB-UIRT?
USB - UIRT Learn Helper Utility. I didn't end up using their whole suite of software as I don't care about that. Kenny was very helpful in getting it. The little utility is exactly what we need. A simple window to past in Hex Code which you can then hold the little box near the device and send a test fire. Or you capture the code from the remote and the hex appears in the window. Short - simple - quick - done.
If you need it, I can help. lemme neaux...
e
