Difference between Serial and Data for IR
Anyone know the difference between the Serial mode and Data mode for IR?
  • ericmedley
    It's probably easiest to think about this from under the hood. In both cases, the IR port is simply sending a series of electrical pulses (on and off) With IR there are a prescribed series of pulses at a certain frequency that translate into on/off flashes that are interpreted as binary (ne: hexidecmal) numbers. With serial, the pulses are set to frequencies that a standard rs232 port understands. but it's still just binary/hex values being inturpreted on the other end.
    the IR port is one-way. So also is the port when set to serial. you can send but not receive.
  • Auser
    Auser Junior Member
    NZRob wrote: »
    From memory the three modes are as follows:
    IR: Usual mode for controlling equipment that has an IR receiver using an IR bud.
    Serial: *Not* one way TTL level serial. Rather, an inverted IR pulse train for controlling some equipment with "wired IR" ports.
    Data: This *is* one way TTL level serial which will control most devices with an RS232 or TTL serial port.
    My memory is hazy on the "Serial" mode - I'm sure someone will correct me if I'm wrong.
