Hex conversion issue - Kalatel CBR-10CDT
Hi all...I'm trying to control a Kalatel CBR-10CDT (basically a CCTV triplex unit) via RS232. It's a very simple (at least the functions that I need) 3-Byte protocol.
Byte 1 = 0xFF
Byte 2 = 0x55
Byte 3 = command byte
What I've been trying to do is use an integer variable, perform a small bit of math, and then convert it to hex. Apparently I'm missing something. For example:
n = 5
SEND_STRING dvCBR, "$FF,$55,ITOHEX(n+8)"
I would think this to send $0D as the third byte (ITOHEX(13)), but what I see being sent out of the NI is $FF, ascii 'U', and then ascii 'D'. I've tried adding an extra set of double quotes around the "ITOHEX(n+8)", as well as doing the math elsewhere and only using "ITOHEX(n)", but nothing seems to work. Any thoughts?
  • bano
    bano Senior Member
    try (8+ITOHEX(n))
    you may get a compiler warning,"String used as a CHAR value in a math operation" but I used this line in switcher code and it works fine for me.
  • dchristo
    dchristo Junior Member
    The ItoHEX function returns an ASCII representation of the hex value, which is why you're seeing the 'D' being returned. If your intent is to send the hex value of $0D (decimal 13), simple skip the ITOHEX conversion. Even though the decimal result of your equation is 13, it is the same bit-pattern as Hex $0D.
    --D
