Pull code from Enova
jabramson
jabramson Junior Member
I'm trying to pull the source code from an Enova unit. I tried my usual tricks for a Netlinx unit (FTP and pull the ../PROG.TKN or transfer .SRC file via file transfer), but those don't seem to work with the Enova. I can get some of the files via the .src file, but it isn't a full project. The FTP GET ../PROG.TKN file doesn't seem to exist on these units.
Anyone know of some tricks to try?
  • DHawthorne
    DHawthorne Junior Member
    The master in an Enova is the same as any other controller in this respect, so there is no different way of getting things. If you are only getting part of the project, then only part was uploaded in the first place. Typically, if support files weren't in the workspace, they don't get uploaded to the master.
