Getting my head around multi-dimensional arrays
All:
So I'm working with two-dimensional arrays and I think I've got a good handle on the correct syntax. Just checking with the forum to make sure.
Ex.
To implement I think my code should look like:
Does that look close?
Norm
Ex.
Camera1Position [2][4] = //two rows, four columns
{4500,250,49,1523}, //row 1 - focus, pan, tilt, zoom
{4500,358,66,1523}
SEND_COMMAND camera1, "'Focus = ',Camera1Position[1][1],'Pan=',Camera1Position[1][2],'Tilt=',Camera1Position[1][3],'Zoom=',Camera1Position[1][4]"
Norm
Yep, you're getting it. You could rewrite the command like this into a funciton.
define_function fn_Send_My_Cam_Command(integer cam_id){ send_command camera1, " 'Focus = ',Camera1Position[cam_id][1], 'Pan= ',Camera1Position[cam_id][2], 'Tilt= ',Camera1Position[cam_id][3], 'Zoom= ',Camera1Position[cam_id][4] " } // define_functionOn a side note: If your intention is to have the text look like this:
"Focus=4500Pan=250 etc..."
You will need to put the variables into an ITOA() function "Integer To ASCII"
otherwise you're going to get some goofy resuls since it will send a literal 4500 decimal.
So it will look like this:
define_function fn_Send_My_Cam_Command(integer cam_id){ send_command camera1, " 'Focus = ',itoa(Camera1Position[cam_id][1]), 'Pan = ',itoa(Camera1Position[cam_id][2]), 'Tilt = ',itoa(Camera1Position[cam_id][3]), 'Zoom = ',itoa(Camera1Position[cam_id][4] )" } // define_functionand for more fun. to prevent the function from accidntally prducing an error you could put a couple traps to prevent bad indexes. In your example you have 2 cameras. So if you accidentally sent the cam_id as 3, it would produce an error (index too large) since you don't have a 3rd row in your array. Also if you accidntally sent cam_id as zero you'd get a zero index error. So put in these traps.
define_function fn_Send_My_Cam_Command(integer cam_id){ if(cam_id){ // cam_id must be greater than zero If(cam_id<3){ // cam_id must be less than 3 send_command camera1, " 'Focus = ',itoa(Camera1Position[cam_id][1]), 'Pan = ',itoa(Camera1Position[cam_id][2]), 'Tilt = ',itoa(Camera1Position[cam_id][3]), 'Zoom = ',itoa(Camera1Position[cam_id][4] )" } // if <3 } // if not zero } // define_functionokay - enough fun for now.
e
