Marantz SR7007
Hi guys,
I have a project with 15 AVR Marantz SR7007 andI use the module form AMX website and it works for one device wich works fine.
Please, help me make it functional for all 15 devices.
I have 15 vdvs and 15 definitions for each device.
I switch nMarantzsr7007 id for each (1 to 15) but i have communication only with first one.
Please help!
thank you!
  • NZRob
    NZRob Member
    Need to post code of your define devices and your usage dude
  • DHawthorne
    DHawthorne Junior Member
    There's not enough information in your post to know for sure what you have done and why it doesn't work. But here are the basics you need to make sure of:
    Every 7007 needs it's own real device number (IR or IP port - you haven't said which you are using)
    Every 7007 needs it's own virtual (which it looks like you have)
    Every 7007 needs it's own instance of the necessary module(s)
