Avb tx multiformat cant connect
Im trying to connect with this unit to upgrade the firmware but failed to connect, in the manual the default ip is 192.168.1.2 but cant ping the unit. I reset it in factory default by presshold for 10 sec the id button but still cant ping the unit. I try direct cable, cross cable but still didn't work. Anybody have same issue and how to solve this thing?
Ok thanks for the advice, second question is, did you ever experience that this transmitter is not responding every day that need to restart everyday to make it work
No, I have seen a power failure require me to reboot before one of 10 TX/RX devices would respond. I don't know why only one freaked-out, but it was a one-time occurrence.
http://www.tp-link.com/en/products/details/?model=TL-MR3040
Best piece of kit I have:
Battery lasts about 6-7 hours ( newer model charges from POE network switch)
DHCP whatever connected device ( got a second one without DHCP to connect to corp networks)
Cheap Cheap
Small and lightweight
Has heaps of other modes as well (mesh them together, connect this to a WIFI network as a client etc)
I rock up to the site, plug this into the rack switch or device and sit in a comfy place with WIFI connected without having to plug and run network cables.
